Ana içeriğe geç
HP Pavilion 17-f127ds Speakers Replacement
Neye ihtiyacın var
  1. HP Pavilion 17-f127ds Speakers Replacement, Battery: adım 1, 3 resimden 1. HP Pavilion 17-f127ds Speakers Replacement, Battery: adım 1, 3 resimden 2. HP Pavilion 17-f127ds Speakers Replacement, Battery: adım 1, 3 resimden 3.
    • Before starting, please turn off your laptop.
    • Slide the battery lock latch, the latch on the left, inwards.
    • Slide the battery release latch on the right inwards to release the battery.
    • The latch may require significant force to slide.
    • Lift the battery up and remove it from computer.
  2. HP Pavilion 17-f127ds Speakers Replacement, Keyboard: adım 2, 2 resimden 1. HP Pavilion 17-f127ds Speakers Replacement, Keyboard: adım 2, 2 resimden 2.
    • Flip your laptop over on a firm surface.
    • Using a Phillips #1 screwdriver, remove the thirteen screws on the back of your laptop.
    • Flip your laptop back over.
  3. HP Pavilion 17-f127ds Speakers Replacement: adım 3, 3 resimden 1. HP Pavilion 17-f127ds Speakers Replacement: adım 3, 3 resimden 2. HP Pavilion 17-f127ds Speakers Replacement: adım 3, 3 resimden 3.
    • Using the opening tools, separate the keyboard from the laptop by prying it from the base along the sides of the laptop.
    • With your fingers, disconnect the keyboard connector and the connector cable from the motherboard.
    • Be careful not to lift the keyboard too high because it might rip off the connectors.
    • Carefully remove the keyboard.
  4. HP Pavilion 17-f127ds Speakers Replacement, Speakers: adım 4, 2 resimden 1. HP Pavilion 17-f127ds Speakers Replacement, Speakers: adım 4, 2 resimden 2.
    • Disconnect the tape connecting the WLAN module to the main board.
    • With a Phillips #0 screwdriver remove the remaining screw holding the speaker in place.
  5. HP Pavilion 17-f127ds Speakers Replacement: adım 5, 2 resimden 1. HP Pavilion 17-f127ds Speakers Replacement: adım 5, 2 resimden 2.
    • Disconnect the speakers from the main board.
    • Lift away the speakers, they are connected with a wire.
Sonuç
Stephen Brown
201 İtibar
2 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S3-G1, Liner Fall 2017 UW Tacoma, Team S3-G1, Liner Fall 2017 üyesi
UWT-LINER-F17S3G1
5 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 382
