Ana içeriğe geç
HP Pavilion 17-g119dx Fan Replacement
Neye ihtiyacın var
  1. HP Pavilion 17-g119dx Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Close your laptop and turn it over so that the bottom is facing up.
  2. HP Pavilion 17-g119dx Fan Replacement: adım 2, 2 resimden 1. HP Pavilion 17-g119dx Fan Replacement: adım 2, 2 resimden 2.
    • In the upper left hand corner, slide the bar with the lock icon to the right. This will unlock the battery.
  3. HP Pavilion 17-g119dx Fan Replacement: adım 3, 2 resimden 1. HP Pavilion 17-g119dx Fan Replacement: adım 3, 2 resimden 2.
    • Slide the bar with the battery icon, on the right of your laptop, to the left to release the battery.
  4. HP Pavilion 17-g119dx Fan Replacement: adım 4, 2 resimden 1. HP Pavilion 17-g119dx Fan Replacement: adım 4, 2 resimden 2.
    • Grab the battery and remove it from the laptop.
  5. HP Pavilion 17-g119dx Fan Replacement, Fan: adım 5, 3 resimden 1. HP Pavilion 17-g119dx Fan Replacement, Fan: adım 5, 3 resimden 2. HP Pavilion 17-g119dx Fan Replacement, Fan: adım 5, 3 resimden 3.
    • Remove the twenty 6.5mm screws using the Phillips #00 screwdriver.
    • Two of these 6.5 mm screws are covered by a silver sticker. Remove the sticker by gently scraping your finger nail under the sticker and then remove the screws.
  6. HP Pavilion 17-g119dx Fan Replacement: adım 6, 3 resimden 1. HP Pavilion 17-g119dx Fan Replacement: adım 6, 3 resimden 2. HP Pavilion 17-g119dx Fan Replacement: adım 6, 3 resimden 3.
    • Remove the black corner covers on either side of the battery to reveal four additional 6.5 mm Phillips #00 screws.
  7. HP Pavilion 17-g119dx Fan Replacement: adım 7, 3 resimden 1. HP Pavilion 17-g119dx Fan Replacement: adım 7, 3 resimden 2. HP Pavilion 17-g119dx Fan Replacement: adım 7, 3 resimden 3.
    • Remove the four 6.5 mm Phillips #00 screws that were underneath the black corner covers.
  8. HP Pavilion 17-g119dx Fan Replacement: adım 8, 3 resimden 1. HP Pavilion 17-g119dx Fan Replacement: adım 8, 3 resimden 2. HP Pavilion 17-g119dx Fan Replacement: adım 8, 3 resimden 3.
    • On the right-hand corner of the laptop, remove the CD-ROM by pressing the small button on the side. Pull it out of the laptop, and set it to the side.
  9. HP Pavilion 17-g119dx Fan Replacement: adım 9, 3 resimden 1. HP Pavilion 17-g119dx Fan Replacement: adım 9, 3 resimden 2. HP Pavilion 17-g119dx Fan Replacement: adım 9, 3 resimden 3.
    Bu adımda kullanılan alet:
    iFixit Opening Tool
    $1.99
    • Make sure that all screws and the CD-ROM Drive are removed before trying to complete this step to prevent damaging your laptop. During this step, you will likely hear loud crackling noises. This is normal.
    • Flip the computer back over with the screen facing up and open the laptop.
    • Use the Plastic Opening Tool to separate the face plate from the backing.
  10. HP Pavilion 17-g119dx Fan Replacement: adım 10, 2 resimden 1. HP Pavilion 17-g119dx Fan Replacement: adım 10, 2 resimden 2.
    • After running the opening tool along the sides, you can pop the keyboard open to access the fan.
    • The fan is located in the lower right corner and is next to the motherboard.
  11. HP Pavilion 17-g119dx Fan Replacement: adım 11, 1 resimden 1.
    Phillips #00 Screwdriver
    $5.49
  12. HP Pavilion 17-g119dx Fan Replacement: adım 12, 3 resimden 1. HP Pavilion 17-g119dx Fan Replacement: adım 12, 3 resimden 2. HP Pavilion 17-g119dx Fan Replacement: adım 12, 3 resimden 3.
    • The fan is connected to the motherboard by a cable. To disconnect the fan, gently push in the sides of the connecter to lift the base of the cable out of the port.
Sonuç
Kathryn
766 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 1,394
