Ana içeriğe geç
HP Pavilion 17-g192dx Screen Replacement
Neye ihtiyacın var
  1. HP Pavilion 17-g192dx Screen Replacement, Battery: adım 1, 3 resimden 1. HP Pavilion 17-g192dx Screen Replacement, Battery: adım 1, 3 resimden 2. HP Pavilion 17-g192dx Screen Replacement, Battery: adım 1, 3 resimden 3.
    • Turn off the laptop.
    • Slide the battery lock to the right until you see the open lock symbol.
  2. HP Pavilion 17-g192dx Screen Replacement: adım 2, 1 resimden 1.
    • Slide the battery release to the left until the battery pops up.
    • This may require significant force.
  3. HP Pavilion 17-g192dx Screen Replacement: adım 3, 2 resimden 1. HP Pavilion 17-g192dx Screen Replacement: adım 3, 2 resimden 2.
    • Lift the battery up.
  4. HP Pavilion 17-g192dx Screen Replacement, Screen: adım 4, 2 resimden 1. HP Pavilion 17-g192dx Screen Replacement, Screen: adım 4, 2 resimden 2.
    • Using the metal spudger, remove the 2 plastic screw covers at the bottom corners of the screen.
  5. HP Pavilion 17-g192dx Screen Replacement: adım 5, 1 resimden 1.
    • Remove the two 7mm screws with a Philips #00 screwdriver.
  6. HP Pavilion 17-g192dx Screen Replacement: adım 6, 3 resimden 1. HP Pavilion 17-g192dx Screen Replacement: adım 6, 3 resimden 2. HP Pavilion 17-g192dx Screen Replacement: adım 6, 3 resimden 3.
    • Use a plastic opening tool to remove the plastic cover surrounding the screen by running the tool around the edge.
    • It may be helpful to start with the metal spudger then transition to the plastic opening tool because you will need the metal tip get in initially.
  7. HP Pavilion 17-g192dx Screen Replacement: adım 7, 3 resimden 1. HP Pavilion 17-g192dx Screen Replacement: adım 7, 3 resimden 2. HP Pavilion 17-g192dx Screen Replacement: adım 7, 3 resimden 3.
    • Remove the four 4 mm screws holding the back to the display assembly with a Philips #00 screwdriver.
    • Remove the two 3mm screws holding the back cover to the display assembly with a Philips #00 screwdriver.
    • Lay the cover on the workspace carefully as not to damage the wires still connected to it.
  8. HP Pavilion 17-g192dx Screen Replacement: adım 8, 1 resimden 1.
    • Unplug the wire connected to the display assembly by gently pulling on it.
    • Tape may be holding it in place.
  9. HP Pavilion 17-g192dx Screen Replacement: adım 9, 2 resimden 1. HP Pavilion 17-g192dx Screen Replacement: adım 9, 2 resimden 2.
    • Remove the four 3mm screws connecting the display assembly to the metal framework with a Philips #00 screwdriver.
    • It may be helpful to have someone else support the screen while you remove it.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 397
