Ana içeriğe geç
HP Pavilion 17-x047na Back Panel Replacement
Neye ihtiyacın var
  1. HP Pavilion 17-x047na Back Panel Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion 17-x047na Back Panel Replacement, Battery: adım 1, 2 resimden 2.
    • Turn off and unplug the laptop before replacing the battery.
    • The netbook needs to be top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
  2. HP Pavilion 17-x047na Back Panel Replacement: adım 2, 1 resimden 1.
    • Slide the battery out from the laptop.
  3. HP Pavilion 17-x047na Back Panel Replacement, Back Panel: adım 3, 2 resimden 1. HP Pavilion 17-x047na Back Panel Replacement, Back Panel: adım 3, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove thirteen 7.0 mm screws from the back case.
    • Using a Phillips #0 screwdriver, remove the CD/DVD drive screw.
    • Use an ejection pin to eject and remove the CD/DVD drive.
  4. HP Pavilion 17-x047na Back Panel Replacement: adım 4, 2 resimden 1. HP Pavilion 17-x047na Back Panel Replacement: adım 4, 2 resimden 2.
    • Use an iFixit opening tool to separate the back cover from the laptop.
    • Gently pry open the cover, trying not to break the plastic.
Sonuç
Sarah Westberg
29.776 İtibar
71 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
120 Üyeler
19.660 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 681
