Ana içeriğe geç
HP Pavilion 17-x047na Fan Replacement
Neye ihtiyacın var
  1. HP Pavilion 17-x047na Fan Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion 17-x047na Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Turn off and unplug the laptop before replacing the battery.
    • The netbook needs to be top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
  2. HP Pavilion 17-x047na Fan Replacement: adım 2, 1 resimden 1.
    • Slide the battery out from the laptop.
  3. HP Pavilion 17-x047na Fan Replacement, Back Panel: adım 3, 2 resimden 1. HP Pavilion 17-x047na Fan Replacement, Back Panel: adım 3, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove thirteen 7.0 mm screws from the back case.
    • Using a Phillips #0 screwdriver, remove the CD/DVD drive screw.
    • Use an ejection pin to eject and remove the CD/DVD drive.
  4. HP Pavilion 17-x047na Fan Replacement: adım 4, 2 resimden 1. HP Pavilion 17-x047na Fan Replacement: adım 4, 2 resimden 2.
    • Use an iFixit opening tool to separate the back cover from the laptop.
    • Gently pry open the cover, trying not to break the plastic.
  5. HP Pavilion 17-x047na Fan Replacement, Fan: adım 5, 1 resimden 1.
    • Remove the five screws attaching the fan to the motherboard using a Phillips #0.
    • Disconnect the wire connecting the fan to the motherboard.
  6. HP Pavilion 17-x047na Fan Replacement: adım 6, 3 resimden 1. HP Pavilion 17-x047na Fan Replacement: adım 6, 3 resimden 2. HP Pavilion 17-x047na Fan Replacement: adım 6, 3 resimden 3.
    • Using a Phillips # 0 screwdriver, remove the five 3.0 mm screws.
    • Disconnect the wire.
    • Then remove the fan.
Sonuç
Khaise Brice
459 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 230
