Giriş
Follow this guide if you need to replace the hard drive of your HP Pavilion 17-x047na.
Neye ihtiyacın var
The netbook needs to be top-side down with the lid closed.
Slide the plastic battery release latches towards the lock symbols.
Using a Phillips #0 screwdriver, remove thirteen 7.0 mm screws from the back case.
Using a Phillips #0 screwdriver, remove the CD/DVD drive screw.
Use an ejection pin to eject and remove the CD/DVD drive.
Bir başkası bu kılavuzu tamamladı.
