Ana içeriğe geç
HP Pavilion 17-x047na Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion 17-x047na Hard Drive Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion 17-x047na Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Turn off and unplug the laptop before replacing the battery.
    • The netbook needs to be top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
  2. HP Pavilion 17-x047na Hard Drive Replacement: adım 2, 1 resimden 1.
    • Slide the battery out from the laptop.
  3. HP Pavilion 17-x047na Hard Drive Replacement, Back Panel: adım 3, 2 resimden 1. HP Pavilion 17-x047na Hard Drive Replacement, Back Panel: adım 3, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove thirteen 7.0 mm screws from the back case.
    • Using a Phillips #0 screwdriver, remove the CD/DVD drive screw.
    • Use an ejection pin to eject and remove the CD/DVD drive.
  4. HP Pavilion 17-x047na Hard Drive Replacement: adım 4, 2 resimden 1. HP Pavilion 17-x047na Hard Drive Replacement: adım 4, 2 resimden 2.
    • Use an iFixit opening tool to separate the back cover from the laptop.
    • Gently pry open the cover, trying not to break the plastic.
  5. HP Pavilion 17-x047na Hard Drive Replacement, Hard Drive: adım 5, 1 resimden 1.
    • Locate the hard drive.
  6. HP Pavilion 17-x047na Hard Drive Replacement: adım 6, 3 resimden 1. HP Pavilion 17-x047na Hard Drive Replacement: adım 6, 3 resimden 2. HP Pavilion 17-x047na Hard Drive Replacement: adım 6, 3 resimden 3.
    • To remove the hard drive, lift both latches to remove the ribbon cable.
    • Once ribbon cable is removed, use the rubber case surrounding the hard drive to lift upwards and pull the hard drive out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Khaise Brice
459 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 481
