Ana içeriğe geç
HP Pavilion 500-259 Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion 500-259 Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 1. HP Pavilion 500-259 Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 2.
    • Power down and unplug all wires from the computer before proceeding.
    • Use a Phillips #1 screwdriver to remove the single 6 mm screw securing the side panel.
    • These screws can often be removed by hand.
  2. HP Pavilion 500-259 Hard Drive Replacement: adım 2, 2 resimden 1. HP Pavilion 500-259 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Slide the front panel back and off the chassis.
  3. HP Pavilion 500-259 Hard Drive Replacement: adım 3, 3 resimden 1. HP Pavilion 500-259 Hard Drive Replacement: adım 3, 3 resimden 2. HP Pavilion 500-259 Hard Drive Replacement: adım 3, 3 resimden 3.
    • The hard drive is found on the left-hand side of the case.
  4. HP Pavilion 500-259 Hard Drive Replacement: adım 4, 3 resimden 1. HP Pavilion 500-259 Hard Drive Replacement: adım 4, 3 resimden 2. HP Pavilion 500-259 Hard Drive Replacement: adım 4, 3 resimden 3.
    • Unplug the two cables attached to the back of the hard drive.
  5. HP Pavilion 500-259 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Place one hand underneath the hard drive to prevent it from falling, then remove the two 2 mm screws attaching the hard drive to the case with a Phillips #2 screwdriver.
  6. HP Pavilion 500-259 Hard Drive Replacement: adım 6, 3 resimden 1. HP Pavilion 500-259 Hard Drive Replacement: adım 6, 3 resimden 2. HP Pavilion 500-259 Hard Drive Replacement: adım 6, 3 resimden 3.
    • Slide the hard drive out of the case.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Farhan Khan
331 İtibar
1 Kılavuz yazıldı
2Kılavuz Yorumları
Why does it look like that drive is mounted sideways with just two screws? The original 3.5" hard drive is mounted flat to the lower 3.5 in mounting Bay. I was looking for advice on how to mount the SSD to the upper 2.5 in mounting Bay. I have serious doubts about the instructions you've posted.
Dave Hill - Yanıt
Hello Dave, this particular HP Pavilion desktop had the hard-drive mounted sideways with two screws, the 2.5" hard-drive being as lightweight as it was able to be supported by just the two screws. I made this guide about a year ago and cannot remember if the hard-drive was able to be mounted flat with the given hole placements. However, I have linked a Youtube video down below that might provide some assistance when trying to mount your 2.5" hard drive despite the video showing a 3.5" drive.
HP Hard drive replacement video: https://www.youtube.com/watch?v=PxT_qPzl...
Thank you for taking the time to look at my guide and I hope this response provides at least a little assistance.
Farhan Khan -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 26
Son 30 gün: 98
Her zaman: 3,650
