Ana içeriğe geç
HP Pavilion DM3-3010US Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion DM3-3010US Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Flip laptop over to back with the battery facing downwards.
    • The battery is the silver cylinder located on the bottom of the laptop.
  2. HP Pavilion DM3-3010US Hard Drive Replacement: adım 2, 1 resimden 1.
    • Locate switch for battery ejection.
    • Battery ejection switch is located just above the left side of the battery.
  3. HP Pavilion DM3-3010US Hard Drive Replacement: adım 3, 1 resimden 1.
    • Remove battery by sliding the battery ejection switch to the right and pulling the battery away from the laptop.
  4. HP Pavilion DM3-3010US Hard Drive Replacement: adım 4, 2 resimden 1. HP Pavilion DM3-3010US Hard Drive Replacement: adım 4, 2 resimden 2.
    • Using a plastic opening tool, remove the large square casing located on the bottom right side of the laptop.
    • The hard drive will be visible once the casing has been removed.
  5. HP Pavilion DM3-3010US Hard Drive Replacement: adım 5, 2 resimden 1. HP Pavilion DM3-3010US Hard Drive Replacement: adım 5, 2 resimden 2.
    • Using a Phillips #0 Screwdriver, remove each of the six Phillips #0 screws.
    • Four screws are located on each corner of the hard-drive.
    • Two screws are located on the right side of the battery slot.
  6. HP Pavilion DM3-3010US Hard Drive Replacement: adım 6, 1 resimden 1.
    • Remove old hard drive from its slot and replace with new hard drive, sticker side facing up.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 1,839
