Ana içeriğe geç
HP Pavilion DV2160BR DVD±RW Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion DV2160BR DVD±RW Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Start with the bottom of the laptop facing up.
  2. HP Pavilion DV2160BR DVD±RW Drive Replacement: adım 2, 2 resimden 1. HP Pavilion DV2160BR DVD±RW Drive Replacement: adım 2, 2 resimden 2.
    • Locate the battery compartment at the rear of the device.
    • There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
  3. HP Pavilion DV2160BR DVD±RW Drive Replacement, DVD±RW Drive: adım 3, 1 resimden 1.
    • Locate the locking screw which is located in a recessed hole on the underside of the laptop.
    • Remove the M2.5X3-Lg #1 Phillips screw.
  4. HP Pavilion DV2160BR DVD±RW Drive Replacement: adım 4, 2 resimden 1. HP Pavilion DV2160BR DVD±RW Drive Replacement: adım 4, 2 resimden 2.
    • Locate the CD drive tray release hole on the front of the drive.
    • Straighten a paper clip and push it gently into the CD drive tray release hole.
    • The drive tray will pop open.
  5. HP Pavilion DV2160BR DVD±RW Drive Replacement: adım 5, 1 resimden 1.
    • Grasp the side edges of the drive tray.
    • Gently pull the drive from the laptop.
  6. HP Pavilion DV2160BR DVD±RW Drive Replacement: adım 6, 1 resimden 1.
    • Locate the mounting bracket which is attached to the back of the drive.
    • Remove the two M2x3-Lg #0 Phillips screws.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brandon MacDonald
239 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-5, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 6-5, Vijaybhaskar Spring 2014 üyesi
UMASSD-VIJAYBHASKAR-S14S6G5
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 8
Her zaman: 236
