Ana içeriğe geç
HP Pavilion DV2160BR Inverter Replacement
Neye ihtiyacın var
  1. HP Pavilion DV2160BR Inverter Replacement, Inverter: adım 1, 1 resimden 1.
    • Start with the laptop sitting up and open.
  2. HP Pavilion DV2160BR Inverter Replacement: adım 2, 3 resimden 1. HP Pavilion DV2160BR Inverter Replacement: adım 2, 3 resimden 2. HP Pavilion DV2160BR Inverter Replacement: adım 2, 3 resimden 3.
    • Remove the 6 rubber screw covers and screws, found around the edge of the laptop screen, surrounded in red and blue.
    • Use the plastic opener tools to remove the screw covers. Just apply firm pressure to the edges to pop the screw covers out, they are attached with a light adhesive.
    • There are four 2.5mm X 4mm-L Phillips #0 screws along the top.
    • There are two 2.5mm X 8mm-L Phillips #1 screws along the bottom.
  3. HP Pavilion DV2160BR Inverter Replacement: adım 3, 2 resimden 1. HP Pavilion DV2160BR Inverter Replacement: adım 3, 2 resimden 2.
    • Slide a plastic opener tool along the outside edges of the front screen panel, separating it from the screen. You may need to apply some firm pressure.
    • Once the panel is separated from the screen, gently pull it off and set it aside.
  4. HP Pavilion DV2160BR Inverter Replacement: adım 4, 2 resimden 1. HP Pavilion DV2160BR Inverter Replacement: adım 4, 2 resimden 2.
    • The inverter is located underneath the screen.
    • Unscrew the two 5mm Phillips #0 screws holding it in place, one on each end of the inverter.
  5. HP Pavilion DV2160BR Inverter Replacement: adım 5, 2 resimden 1. HP Pavilion DV2160BR Inverter Replacement: adım 5, 2 resimden 2.
    • Disconnect the grey LCD cable on the left side of the inverter by holding the inverter in place and pulling firmly on the connector.
    • Disconnect the backlight plug cable on the right side of the inverter by holding the inverter in place and pulling firmly on the connector.
  6. HP Pavilion DV2160BR Inverter Replacement: adım 6, 1 resimden 1.
    • Remove the inverter from the device.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Shannon
55 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-66, Johann Spring 2013 Cal Poly, Team 13-66, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S13G66
3 Üyeler
Bir Yorum
Thank you for enriching my knowledge.
Hope to meet you again.
ashique mahamud - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 1,363
