Ana içeriğe geç
HP Pavilion DV2160BR RAM Replacement
Neye ihtiyacın var
  1. HP Pavilion DV2160BR RAM Replacement, RAM: adım 1, 2 resimden 1. HP Pavilion DV2160BR RAM Replacement, RAM: adım 1, 2 resimden 2.
    • Start with the bottom of the laptop facing up.
    • Locate the panel that is covering the RAM compartment.
    • Unscrew the two 5mm Phillips #0 screws that are securing the RAM compartment.
  2. HP Pavilion DV2160BR RAM Replacement: adım 2, 2 resimden 1. HP Pavilion DV2160BR RAM Replacement: adım 2, 2 resimden 2.
    • Lift up the panel that is by the end that held the screws. Set it aside.
  3. HP Pavilion DV2160BR RAM Replacement: adım 3, 3 resimden 1. HP Pavilion DV2160BR RAM Replacement: adım 3, 3 resimden 2. HP Pavilion DV2160BR RAM Replacement: adım 3, 3 resimden 3.
    • Using 2 prying tools, push the 2 buttons on the sides of one RAM module simultaneously, so that one side of the module pops up and out of the clips holding it down.
    • Grab the RAM module and carefully pull it straight out of its slot.
    • Repeat this step for the second RAM module, which is located just underneath the first RAM module.
Sonuç
Shannon
55 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-66, Johann Spring 2013 Cal Poly, Team 13-66, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S13G66
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 382
