Ana içeriğe geç
HP Pavilion DV2160BR Webcam Replacement
Neye ihtiyacın var
  1. HP Pavilion DV2160BR Webcam Replacement, Battery: adım 1, 1 resimden 1.
    • Start with the bottom of the laptop facing up.
  2. HP Pavilion DV2160BR Webcam Replacement: adım 2, 2 resimden 1. HP Pavilion DV2160BR Webcam Replacement: adım 2, 2 resimden 2.
    • Locate the battery compartment at the rear of the device.
    • There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
  3. HP Pavilion DV2160BR Webcam Replacement, Webcam: adım 3, 1 resimden 1.
    • Flip over the laptop and open it.
  4. HP Pavilion DV2160BR Webcam Replacement: adım 4, 2 resimden 1. HP Pavilion DV2160BR Webcam Replacement: adım 4, 2 resimden 2.
    • Remove the 6 rubber screw covers from the screen panel using the plastic opener tools by applying firm pressure to the edges.
    • The 4 screw covers on top are attached by an adhesive backing.
    • The 2 screw covers on the bottom are rubber plugs.
  5. HP Pavilion DV2160BR Webcam Replacement: adım 5, 1 resimden 1.
    • Remove the 4 M2.5x4-Lg #0 Phillips screws from the top of the screen panel.
    • Remove the 2 M2.5x8-Lg #1 Phillips screws from the bottom of the screen panel.
  6. HP Pavilion DV2160BR Webcam Replacement: adım 6, 2 resimden 1. HP Pavilion DV2160BR Webcam Replacement: adım 6, 2 resimden 2.
    • Slide a plastic opener tool along the outside edges of the front screen panel to start to separate it from the back screen panel.
    • You may need to apply some firm pressure to get it started.
    • Once it has started to separate, gently pull off the screen panel by working along the edge, and set it aside.
  7. HP Pavilion DV2160BR Webcam Replacement: adım 7, 1 resimden 1.
    • Locate the screw on the left side of the cameras mounting bracket.
    • Remove the M2.5x4-Lg #0 Phillips screw
  8. HP Pavilion DV2160BR Webcam Replacement: adım 8, 1 resimden 1.
    • Pull the camera from the back screen panel and rotate it so you are looking at the back.
    • Remove the 2 M2x3-Lg #00 Phillips screws and place the mounting bracket aside.
  9. HP Pavilion DV2160BR Webcam Replacement: adım 9, 1 resimden 1.
    • Disconnect the cable on the right side of the camera board by pulling firmly on the connector.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brandon MacDonald
239 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-5, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 6-5, Vijaybhaskar Spring 2014 üyesi
UMASSD-VIJAYBHASKAR-S14S6G5
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 789
