Ana içeriğe geç
HP Pavilion DV2160BR Wifi Adapter Replacement
Neye ihtiyacın var
  1. HP Pavilion DV2160BR Wifi Adapter Replacement, Wifi Adapter: adım 1, 2 resimden 1. HP Pavilion DV2160BR Wifi Adapter Replacement, Wifi Adapter: adım 1, 2 resimden 2.
    • Start with the bottom of the laptop facing up.
    • Locate the small panel under the battery, which houses the wifi adapter, and unscrew the one 5mm Phillips #0 screw holding the panel in place.
    • Remove the panel and set it aside.
    • Be careful not to snap the 2 tabs on the sides of the panel when pulling it out.
  2. HP Pavilion DV2160BR Wifi Adapter Replacement: adım 2, 2 resimden 1. HP Pavilion DV2160BR Wifi Adapter Replacement: adım 2, 2 resimden 2.
    • Unscrew the two 3mm Phillips #0 screw which is located at the corners of the wifi adapter.
  3. HP Pavilion DV2160BR Wifi Adapter Replacement: adım 3, 2 resimden 1. HP Pavilion DV2160BR Wifi Adapter Replacement: adım 3, 2 resimden 2.
    • Pull the 2 black wires with the gold pieces out of the wifi adapter.
    • The wifi adapter is now free to be removed.
    • When reconnecting the wires for re-installing the wifi adapter, make sure the gold ends are rotated correctly to be properly pushed back in.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Shannon
55 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-66, Johann Spring 2013 Cal Poly, Team 13-66, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S13G66
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 508
