Ana içeriğe geç
HP Pavilion DV3 HP Pavilion Wireless Card Replacement
Neye ihtiyacın var
  1. HP Pavilion DV3 HP Pavilion Wireless Card Replacement, Battery: adım 1, 1 resimden 1.
    • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
    • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
  2. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: adım 2, 2 resimden 1. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: adım 2, 2 resimden 2.
    • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
  3. HP Pavilion DV3 HP Pavilion Wireless Card Replacement, Wireless Card: adım 3, 1 resimden 1.
    • With the laptop upside down, locate the three screws on the wireless card cover and unscrew the screws.
    • All three screws will have a 3.5 mm diameter head.
    • Two of the screws will be silver, 7mm in length, and will stay attached to the cover.
    • One screw will be black, 13mm in length, and will separate from the cover. Set this screw aside.
  4. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: adım 4, 2 resimden 1. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: adım 4, 2 resimden 2.
    • Grab one of the edges to the cover and lift up (towards you).
    • Set the cover to the side.
    • The wireless card will now be exposed.
  5. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: adım 5, 3 resimden 1. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: adım 5, 3 resimden 2. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: adım 5, 3 resimden 3.
    • Using your hand, pull the black and white antenna wires upwards.
    • This will disconnect the antenna wires from the card.
  6. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: adım 6, 2 resimden 1. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: adım 6, 2 resimden 2.
    • Locate the two black screws connecting the wireless card to the laptop. They will have a 3.5 mm diameter head and be 4mm long. Remove the screws.
    • Once the screws are removed, the wireless card will pop up.
  7. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: adım 7, 2 resimden 1. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: adım 7, 2 resimden 2.
    • Grab the sides of the wireless card and pull it up and to the left to disconnect from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brandon Baldovin
548 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-10, Forte Fall 2013 Cal Poly, Team 14-10, Forte Fall 2013 üyesi
CPSU-FORTE-F13S14G10
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 1,649
