Ana içeriğe geç
HP Pavilion DV3 Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion DV3 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
    • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
    FixBot'a Sor
    Yorum Ekle
  2. HP Pavilion DV3 Hard Drive Replacement: adım 2, 2 resimden 1. HP Pavilion DV3 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
    FixBot'a Sor
    Yorum Ekle
  3. HP Pavilion DV3 Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Locate the screw for the hard drive cover (The cover has HP ProtectSmart written on it).
    • Remove the 3.5 mm diameter, 7 mm long screw with your Phillips PH1 screwdriver.
    • The screw will remain attached to the cover.
    FixBot'a Sor
    Yorum Ekle
  4. HP Pavilion DV3 Hard Drive Replacement: adım 4, 2 resimden 1. HP Pavilion DV3 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Grab the raised edge of the cover lift up. This will separate the cover from the laptop.
    • Put the cover and screw to the.
    • This will reveal the hard drive.
    FixBot'a Sor
    Yorum Ekle
  5. HP Pavilion DV3 Hard Drive Replacement: adım 5, 3 resimden 1. HP Pavilion DV3 Hard Drive Replacement: adım 5, 3 resimden 2. HP Pavilion DV3 Hard Drive Replacement: adım 5, 3 resimden 3.
    • With your fingers, grab the clear tab.
    • Pull right first, and then upwards (towards you).
    • The hard drive should slide out of place and detach from the laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Luke Whitmarsh
649 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-10, Forte Fall 2013 Cal Poly, Team 14-10, Forte Fall 2013 üyesi
CPSU-FORTE-F13S14G10
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 41
Her zaman: 5,402
