Giriş
This guide will demonstrate how to remove the hard drive from you laptop. You will need the screwdriver listed in the tools section.
Neye ihtiyacın var
Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
The yellow highlighted edge of the battery should pop up slightly when the switch is moved
Remove the 3.5 mm diameter, 7 mm long screw with your Phillips PH1 screwdriver.
5 farklı kişi bu kılavuzu tamamladı.
