Ana içeriğe geç
HP Pavilion DV3 RAM Replacement
Neye ihtiyacın var
  1. HP Pavilion DV3 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
    • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
    FixBot'a Sor
    Yorum Ekle
  2. HP Pavilion DV3 RAM Replacement: adım 2, 2 resimden 1. HP Pavilion DV3 RAM Replacement: adım 2, 2 resimden 2.
    • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
    FixBot'a Sor
    Yorum Ekle
  3. HP Pavilion DV3 RAM Replacement, RAM: adım 3, 3 resimden 1. HP Pavilion DV3 RAM Replacement, RAM: adım 3, 3 resimden 2. HP Pavilion DV3 RAM Replacement, RAM: adım 3, 3 resimden 3.
    • Remove the two 3.5 mm diameter head and 7 mm long screws using the Philips PH1 screwdriver.
    • Both screws will remain attached to the cover.
    • Set the cover with attached screws to the side.
    • The RAM will now be exposed
    FixBot'a Sor
    Yorum Ekle
  4. HP Pavilion DV3 RAM Replacement: adım 4, 3 resimden 1. HP Pavilion DV3 RAM Replacement: adım 4, 3 resimden 2. HP Pavilion DV3 RAM Replacement: adım 4, 3 resimden 3.
    • Find the two clips located on each side of the RAM.
    • Using both hands, simultaneously grab each clip and open them away from the RAM stick.
    • The RAM will pop up.
    FixBot'a Sor
    Yorum Ekle
  5. HP Pavilion DV3 RAM Replacement: adım 5, 2 resimden 1. HP Pavilion DV3 RAM Replacement: adım 5, 2 resimden 2.
    • Using one hand, pull the RAM up and to the left to remove it.
    FixBot'a Sor
    Yorum Ekle
  6. HP Pavilion DV3 RAM Replacement: adım 6, 1 resimden 1.
    • If there is a second RAM module present (as shown), repeat steps 2 and 3 to remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Brandon Baldovin
548 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-10, Forte Fall 2013 Cal Poly, Team 14-10, Forte Fall 2013 üyesi
CPSU-FORTE-F13S14G10
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 21
Her zaman: 2,349
