Ana içeriğe geç
HP Pavilion DV5T-1000 Hard Drive Replacement
Neye ihtiyacın var
    • Make sure the laptop is turned off, and the power cable is removed.
    • Leaving the laptop turned on can cause damage to the hardware and any stored data.
  1. HP Pavilion DV5T-1000 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Turn the laptop over to access the backside of the computer.
    • Identify and confirm that the laptop is an HP Pavilion DV5T-1000.
  2. HP Pavilion DV5T-1000 Hard Drive Replacement: adım 3, 2 resimden 1. HP Pavilion DV5T-1000 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Slide the battery lock to the left, it's located just below the battery compartment.
    • Pull the battery up and out, to remove it from the battery compartment.
    • To prevent hardware damage, remove the battery before working on the laptop.
  3. HP Pavilion DV5T-1000 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Identify the hard drive compartment, located at the top left-hand frame of the laptop.
  4. HP Pavilion DV5T-1000 Hard Drive Replacement: adım 5, 1 resimden 1.
    • In order to remove the hard drive compartment cover, first remove the two screws located on the panel, using a size 0 Phillips head screwdriver.
  5. HP Pavilion DV5T-1000 Hard Drive Replacement: adım 6, 1 resimden 1.
    • Expose the hard drive by lifting the drive cover.
  6. HP Pavilion DV5T-1000 Hard Drive Replacement: adım 7, 1 resimden 1.
    • In order to loosen the hard drive from the motherboard, tug gently on the black tabs located at both ends of the hard drive.
    • Be cautious when handling the cable that connects the hard drive to the computer's motherboard.
  7. HP Pavilion DV5T-1000 Hard Drive Replacement: adım 8, 2 resimden 1. HP Pavilion DV5T-1000 Hard Drive Replacement: adım 8, 2 resimden 2.
    • Firmly hold both the black plug, and the hard drive itself to separate the drive from the cable.
  8. HP Pavilion DV5T-1000 Hard Drive Replacement: adım 9, 2 resimden 1. HP Pavilion DV5T-1000 Hard Drive Replacement: adım 9, 2 resimden 2.
    • Remove the 4 screws using a size 0 Phillips head screwdriver.
    • Remove the metal from the perimeter of the hard drive.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Josh Taimanglo
165 İtibar
1 Kılavuz yazıldı
Ekip
1Rehber Yorum
Help after replacing hard drive installation of windows
Bettyjean Serrano - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 29
Her zaman: 2,088
