Ana içeriğe geç
HP Pavilion DV9700 Optical Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion DV9700 Optical Drive  Replacement, Optical Drive: adım 1, 3 resimden 1. HP Pavilion DV9700 Optical Drive  Replacement, Optical Drive: adım 1, 3 resimden 2. HP Pavilion DV9700 Optical Drive  Replacement, Optical Drive: adım 1, 3 resimden 3.
    • Turn the device over so that the bottom is facing upward.
    • Find the screw with an imprint of a disk underneath it. It is located near the center of the device.
    • Remove this 6mm screw with a Philips #0 screwdriver.
    • This screw is very small, make sure to have an organized place to put it.
  2. HP Pavilion DV9700 Optical Drive  Replacement: adım 2, 3 resimden 1. HP Pavilion DV9700 Optical Drive  Replacement: adım 2, 3 resimden 2. HP Pavilion DV9700 Optical Drive  Replacement: adım 2, 3 resimden 3.
    • The optical drive is located toward the left side of the device.
    • Using a spudger, pry the optical drive away from the casing.
    • Pull the rest of the optical drive out with your hand.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Max Shangraw
507 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G1, Bernier Spring 2018 UMass Dartmouth, Team S6-G1, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S6G1
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 334
