Ana içeriğe geç
HP Pavilion DV9700 RAM Replacement
Neye ihtiyacın var
  1. HP Pavilion DV9700 RAM Replacement, RAM: adım 1, 2 resimden 1. HP Pavilion DV9700 RAM Replacement, RAM: adım 1, 2 resimden 2.
    • Turn the device over so that the bottom is facing upward.
    • Locate the three panels near the bottom half of the device.
    • The middle-most panel is the one we will be focusing on.
    • Using a Philips #0 screwdriver, unscrew the two 4mm screws that hold this panel in place.
  2. HP Pavilion DV9700 RAM Replacement: adım 2, 2 resimden 1. HP Pavilion DV9700 RAM Replacement: adım 2, 2 resimden 2.
    • Pull the bottom of the panel upward.
    • Then pull the panel toward yourself to remove.
  3. HP Pavilion DV9700 RAM Replacement: adım 3, 3 resimden 1. HP Pavilion DV9700 RAM Replacement: adım 3, 3 resimden 2. HP Pavilion DV9700 RAM Replacement: adım 3, 3 resimden 3.
    • Look toward the top half of the exposed compartment.
    • Each ram stick will have two silver clips on the left and right side.
    • Push these clips outward at the same time to release the ram stick.
  4. HP Pavilion DV9700 RAM Replacement: adım 4, 3 resimden 1. HP Pavilion DV9700 RAM Replacement: adım 4, 3 resimden 2. HP Pavilion DV9700 RAM Replacement: adım 4, 3 resimden 3.
    • The ram stick will be held at a 45 degree angle. Pull the stick upward to release it from the slot.
    • Each ram stick will have a notch near the bottom, make sure to keep note of which side this notch is on.
    • Make sure to place the ram away from any static surfaces (carpet, fabric, etc.)
Sonuç
Max Shangraw
507 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G1, Bernier Spring 2018 UMass Dartmouth, Team S6-G1, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S6G1
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 743
