Ana içeriğe geç
HP Pavilion G6 Screen Replacement
Neye ihtiyacın var
  1. HP Pavilion G6  Screen Replacement, Remove the battery: adım 1, 3 resimden 1. HP Pavilion G6  Screen Replacement, Remove the battery: adım 1, 3 resimden 2. HP Pavilion G6  Screen Replacement, Remove the battery: adım 1, 3 resimden 3.
    • Close the laptop and flip it over.
    • Slide the release pin to pop the battery.
    • Remove the battery completely.
    FixBot'a Sor
    Yorum Ekle
  2. HP Pavilion G6  Screen Replacement, Remove the screw covers: adım 2, 3 resimden 1. HP Pavilion G6  Screen Replacement, Remove the screw covers: adım 2, 3 resimden 2. HP Pavilion G6  Screen Replacement, Remove the screw covers: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Open the laptop and locate the screw covers.
    • Remove the screw covers at the bottom of the screen with tweezers.
    • Keep them somewhere safe as you will need to stick them back after the repair.
    FixBot'a Sor
    Yorum Ekle
  3. HP Pavilion G6  Screen Replacement, Remove the plastic frame: adım 3, 3 resimden 1. HP Pavilion G6  Screen Replacement, Remove the plastic frame: adım 3, 3 resimden 2. HP Pavilion G6  Screen Replacement, Remove the plastic frame: adım 3, 3 resimden 3.
    • Unscrew the exposed 2 x Philips screws and set them aside.
    • Starting from the top, pry up the plastic frame with your fingernails or a pry bar.
    • If you are using a pry bar, it can scratch the screen. Apply gentle pressure until the plastic frame pop out all around the frame. Don't force it!
    • Finally, remove the frame.
    FixBot'a Sor
    Yorum Ekle
  4. HP Pavilion G6  Screen Replacement, Release the screen from the frame: adım 4, 3 resimden 1. HP Pavilion G6  Screen Replacement, Release the screen from the frame: adım 4, 3 resimden 2. HP Pavilion G6  Screen Replacement, Release the screen from the frame: adım 4, 3 resimden 3.
    • Remove the black Philips screw from the top on each side.
    • Remove the bottom screw from the hinge to make an easier access to the screws on the side of the screen.
    • Now that the frame is loose, you can remove the 4 x Philips screws holding the screen in the frame.
    FixBot'a Sor
    Yorum Ekle
  5. HP Pavilion G6  Screen Replacement, Disconnect the screen connector: adım 5, 3 resimden 1. HP Pavilion G6  Screen Replacement, Disconnect the screen connector: adım 5, 3 resimden 2. HP Pavilion G6  Screen Replacement, Disconnect the screen connector: adım 5, 3 resimden 3.
    • Turn the laptop back up and carefully tilt the screen out from the frame and rest it on the keyboard.
    • Don't try to fully remove it yet as it is still attached to the motherboard by the screen cable!
    • Gently lift up the adhesive and disconnect the screen connector. That is the screen released and ready for a change for a new one.
    FixBot'a Sor
    Yorum Ekle
  6. HP Pavilion G6  Screen Replacement, Check the model number before ordering: adım 6, 2 resimden 1. HP Pavilion G6  Screen Replacement, Check the model number before ordering: adım 6, 2 resimden 2.
    • Before ordering a new screen make sure that you order the correct model number that is compatible with your old screen.
    • Check the cable connector to make sure you order the correct screen with the correct number of pins.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
honakrisi
4.155 İtibar
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 58
Her zaman: 2,170
