Ana içeriğe geç
HP Pavilion G60-120US Keyboard Replacement
Neye ihtiyacın var
  1. HP Pavilion G60-120US Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the laptop is turned off.
    • Turn the laptop over to reveal the battery.
  2. HP Pavilion G60-120US Keyboard Replacement: adım 2, 2 resimden 1. HP Pavilion G60-120US Keyboard Replacement: adım 2, 2 resimden 2.
    • Slide and hold the battery release switch to the left to release the battery from the device.
  3. HP Pavilion G60-120US Keyboard Replacement: adım 3, 2 resimden 1. HP Pavilion G60-120US Keyboard Replacement: adım 3, 2 resimden 2.
    • While holding the battery release switch, grab the battery and pull it upward gently.
  4. HP Pavilion G60-120US Keyboard Replacement, Keyboard: adım 4, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove the seven 4.0mm screws on the battery compartment of the laptop.
  5. HP Pavilion G60-120US Keyboard Replacement: adım 5, 2 resimden 1. HP Pavilion G60-120US Keyboard Replacement: adım 5, 2 resimden 2.
    • Using the Phillips #0 screwdriver, remove two 4.0mm screws from the hard disk cover.
    • Remove the hard disk cover.
  6. HP Pavilion G60-120US Keyboard Replacement: adım 6, 2 resimden 1. HP Pavilion G60-120US Keyboard Replacement: adım 6, 2 resimden 2.
    • Remove the hard drive by pulling gently and disconnecting the hard drive from the laptop.
    • Gently pull on the black and red wiring on the bottom left to separate the wire from the component.
  7. HP Pavilion G60-120US Keyboard Replacement: adım 7, 1 resimden 1.
    • Remove the two 4.0 mm Phillips #0 screws from the hard disk compartment.
  8. HP Pavilion G60-120US Keyboard Replacement: adım 8, 3 resimden 1. HP Pavilion G60-120US Keyboard Replacement: adım 8, 3 resimden 2. HP Pavilion G60-120US Keyboard Replacement: adım 8, 3 resimden 3.
    • Using the Phillips #0 screwdriver, remove the two 4.0 mm screws from the memory card cover.
    • Remove the memory disk cover.
  9. HP Pavilion G60-120US Keyboard Replacement: adım 9, 3 resimden 1. HP Pavilion G60-120US Keyboard Replacement: adım 9, 3 resimden 2. HP Pavilion G60-120US Keyboard Replacement: adım 9, 3 resimden 3.
    • Using the Phillips #0 screwdriver, remove the 4.0 mm screw from the Wi-Fi chip cover.
    • Remove the Wi-Fi chip cover.
  10. HP Pavilion G60-120US Keyboard Replacement: adım 10, 2 resimden 1. HP Pavilion G60-120US Keyboard Replacement: adım 10, 2 resimden 2.
    • Using the Phillips #0 screwdriver, remove the two 3.0 mm screws securing the Wi-Fi chip in place.
    • Grab the Wi-Fi chip and pull up gently to the left to disconnect it from the laptop.
  11. HP Pavilion G60-120US Keyboard Replacement: adım 11, 2 resimden 1. HP Pavilion G60-120US Keyboard Replacement: adım 11, 2 resimden 2.
    • Disconnect the two wires connecting the chip's base.
    • Remove the Wi-Fi chip.
  12. HP Pavilion G60-120US Keyboard Replacement: adım 12, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove the seven 4.0 mm screws on the bottom of the laptop.
  13. HP Pavilion G60-120US Keyboard Replacement: adım 13, 3 resimden 1. HP Pavilion G60-120US Keyboard Replacement: adım 13, 3 resimden 2. HP Pavilion G60-120US Keyboard Replacement: adım 13, 3 resimden 3.
    • Turn the laptop back to its upright state.
    • Insert an opening tool into the upper right corner of the keyboard and gently lift it to separate it from the laptop.
    • Be sure not to apply excessive pressure to prevent the bending and breaking of the keyboard.
    • Do not pull the keyboard all the way out because there is a wiring connection under the keyboard.
  14. HP Pavilion G60-120US Keyboard Replacement: adım 14, 3 resimden 1. HP Pavilion G60-120US Keyboard Replacement: adım 14, 3 resimden 2. HP Pavilion G60-120US Keyboard Replacement: adım 14, 3 resimden 3.
    • Grab the wiring and gently pull it out to disconnect it from the laptop.
    • Don't use excessive force.
    • Remove the keyboard.
Sonuç
Kristen Gismondi
81.591 İtibar
200 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.718 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 142
