Ana içeriğe geç
HP Pavilion G60-247CL RAM Replacement
Neye ihtiyacın var
    1. HP Pavilion G60-247CL RAM Replacement, Battery: adım 1, 3 resimden 1. HP Pavilion G60-247CL RAM Replacement, Battery: adım 1, 3 resimden 2. HP Pavilion G60-247CL RAM Replacement, Battery: adım 1, 3 resimden 3.
      • Press down and to the right on the battery lock slide.
      • Once slid over to the right the battery will pop up and out.
      FixBot'a Sor
      Yorum Ekle
    1. HP Pavilion G60-247CL RAM Replacement, RAM: adım 2, 1 resimden 1.
      • Locate RAM access door on the bottom side of the laptop.
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion G60-247CL RAM Replacement: adım 3, 3 resimden 1. HP Pavilion G60-247CL RAM Replacement: adım 3, 3 resimden 2. HP Pavilion G60-247CL RAM Replacement: adım 3, 3 resimden 3.
      • Remove the two screws holding down the RAM access door with a Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. HP Pavilion G60-247CL RAM Replacement: adım 4, 2 resimden 1. HP Pavilion G60-247CL RAM Replacement: adım 4, 2 resimden 2.
      • Lift up on the RAM cover and remove it to reveal RAM sticks.
      FixBot'a Sor
      Yorum Ekle
    4. HP Pavilion G60-247CL RAM Replacement: adım 5, 2 resimden 1. HP Pavilion G60-247CL RAM Replacement: adım 5, 2 resimden 2.
      • Gently pull apart the two metal tabs located on both sides of the stick of RAM.
      FixBot'a Sor
      Yorum Ekle
    5. HP Pavilion G60-247CL RAM Replacement: adım 6, 1 resimden 1.
      • Gently lift the RAM stick up and out of its seat.
      FixBot'a Sor
      Yorum Ekle
    6. HP Pavilion G60-247CL RAM Replacement: adım 7, 1 resimden 1.
      • Repeat the previous two steps for the remaining stick of RAM.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Zachary Herrera
485 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G5, Covino Spring 2018 UMass Dartmouth, Team S4-G5, Covino Spring 2018 üyesi
UMASSD-COVINO-S18S4G5
3 Üyeler
33 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 26
Her zaman: 420
