Ana içeriğe geç
HP Pavilion G60-247CL Screen Replacement
Neye ihtiyacın var
    1. HP Pavilion G60-247CL Screen Replacement, Battery: adım 1, 3 resimden 1. HP Pavilion G60-247CL Screen Replacement, Battery: adım 1, 3 resimden 2. HP Pavilion G60-247CL Screen Replacement, Battery: adım 1, 3 resimden 3.
      • Press down and to the right on the battery lock slide.
      • Once slid over to the right the battery will pop up and out.
      FixBot'a Sor
      Yorum Ekle
    1. HP Pavilion G60-247CL Screen Replacement, Screen: adım 2, 1 resimden 1.
      • Remove the seven Phillips #1 screws from the back side of the laptop.
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion G60-247CL Screen Replacement: adım 3, 2 resimden 1. HP Pavilion G60-247CL Screen Replacement: adım 3, 2 resimden 2.
      • Remove the seven Phillips #0 screws from the battery compartment.
      FixBot'a Sor
      Yorum Ekle
    3. HP Pavilion G60-247CL Screen Replacement: adım 4, 3 resimden 1. HP Pavilion G60-247CL Screen Replacement: adım 4, 3 resimden 2. HP Pavilion G60-247CL Screen Replacement: adım 4, 3 resimden 3.
      • Turn the computer around to the front side.
      • Using an opening tool, prop open the keyboard casing.
      FixBot'a Sor
      Yorum Ekle
    4. HP Pavilion G60-247CL Screen Replacement: adım 5, 3 resimden 1. HP Pavilion G60-247CL Screen Replacement: adım 5, 3 resimden 2. HP Pavilion G60-247CL Screen Replacement: adım 5, 3 resimden 3.
      • Carefully lift up the keyboard.
      • Gently pull up the connecting wire clip (located in the middle) to completely detach the keyboard.
      FixBot'a Sor
      Yorum Ekle
    5. HP Pavilion G60-247CL Screen Replacement: adım 6, 3 resimden 1. HP Pavilion G60-247CL Screen Replacement: adım 6, 3 resimden 2. HP Pavilion G60-247CL Screen Replacement: adım 6, 3 resimden 3.
      • At the top right of the laptop there will be another wire clip holding the keyboard casing.
      • Carefully pull out the wire clip to fully detach the covering.
      FixBot'a Sor
      Yorum Ekle
    6. HP Pavilion G60-247CL Screen Replacement: adım 7, 2 resimden 1. HP Pavilion G60-247CL Screen Replacement: adım 7, 2 resimden 2.
      Bu adımda kullanılan alet:
      • At the top right of the laptop remove the black wire from under the metal tabs using the tweezers.
      FixBot'a Sor
      Yorum Ekle
    7. HP Pavilion G60-247CL Screen Replacement: adım 8, 2 resimden 1. HP Pavilion G60-247CL Screen Replacement: adım 8, 2 resimden 2.
      • Remove the black wire from the top right corner by gently pulling outward.
      FixBot'a Sor
      Yorum Ekle
    8. HP Pavilion G60-247CL Screen Replacement: adım 9, 2 resimden 1. HP Pavilion G60-247CL Screen Replacement: adım 9, 2 resimden 2.
      • At the top left of the computer remove the black clip using the opening tool.
      • Push the opening tool to the right to pop out the clip.
      FixBot'a Sor
      Yorum Ekle
    9. HP Pavilion G60-247CL Screen Replacement: adım 10, 3 resimden 1. HP Pavilion G60-247CL Screen Replacement: adım 10, 3 resimden 2. HP Pavilion G60-247CL Screen Replacement: adım 10, 3 resimden 3.
      • Locate at the bottom left of the computer a white clip.
      • Using an opening tool, prop out the white clip.
      FixBot'a Sor
      Yorum Ekle
    10. HP Pavilion G60-247CL Screen Replacement: adım 11, 2 resimden 1. HP Pavilion G60-247CL Screen Replacement: adım 11, 2 resimden 2.
      • On the left side of the computer locate the black wire with the clear clip.
      • Gently pull the wire to the right to detach it.
      FixBot'a Sor
      Yorum Ekle
    11. HP Pavilion G60-247CL Screen Replacement: adım 12, 3 resimden 1. HP Pavilion G60-247CL Screen Replacement: adım 12, 3 resimden 2. HP Pavilion G60-247CL Screen Replacement: adım 12, 3 resimden 3.
      • At the top corners of the computer, unscrew the three Phillips #0 screws.
      • Lift up the top half of the computer carefully.
      FixBot'a Sor
      Yorum Ekle
    12. HP Pavilion G60-247CL Screen Replacement: adım 13, 3 resimden 1. HP Pavilion G60-247CL Screen Replacement: adım 13, 3 resimden 2. HP Pavilion G60-247CL Screen Replacement: adım 13, 3 resimden 3.
      • Locate the two screws at the bottom corners of the screen.
      • Using the tweezers remove the rubber black covering over the screw.
      • Remove the two Phillips #0 screws.
      FixBot'a Sor
      Yorum Ekle
    13. HP Pavilion G60-247CL Screen Replacement: adım 14, 3 resimden 1. HP Pavilion G60-247CL Screen Replacement: adım 14, 3 resimden 2. HP Pavilion G60-247CL Screen Replacement: adım 14, 3 resimden 3.
      • Using the opening tool, prop off the screen covering.
      • Remove the covering to expose the screen completely.
      FixBot'a Sor
      Yorum Ekle
    14. HP Pavilion G60-247CL Screen Replacement: adım 15, 3 resimden 1. HP Pavilion G60-247CL Screen Replacement: adım 15, 3 resimden 2. HP Pavilion G60-247CL Screen Replacement: adım 15, 3 resimden 3.
      • Remove the bottom two screen bearings.
      • Using a Phillips 1 screwdriver, remove the two screws on each side.
      FixBot'a Sor
      Yorum Ekle
    15. HP Pavilion G60-247CL Screen Replacement: adım 16, 2 resimden 1. HP Pavilion G60-247CL Screen Replacement: adım 16, 2 resimden 2.
      • Using the tweezers remove the red and white wire from the bottom of the screen.
      FixBot'a Sor
      Yorum Ekle
    16. HP Pavilion G60-247CL Screen Replacement: adım 17, 2 resimden 1. HP Pavilion G60-247CL Screen Replacement: adım 17, 2 resimden 2.
      • Prop the screen up slightly.
      • Using the tweezers unclip the white wire.
      FixBot'a Sor
      Yorum Ekle
    17. HP Pavilion G60-247CL Screen Replacement: adım 18, 2 resimden 1. HP Pavilion G60-247CL Screen Replacement: adım 18, 2 resimden 2.
      • While the screen is still propped open, remove the black wire from the bottom middle of the screen by pulling gently.
      FixBot'a Sor
      Yorum Ekle
    18. HP Pavilion G60-247CL Screen Replacement: adım 19, 1 resimden 1.
      • Remove the screen from the outer casing carefully.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Haley Matthews
517 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G5, Covino Spring 2018 UMass Dartmouth, Team S4-G5, Covino Spring 2018 üyesi
UMASSD-COVINO-S18S4G5
3 Üyeler
38 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 645
