Ana içeriğe geç
HP Pavilion G60-630US RAM Replacement
Neye ihtiyacın var
    1. HP Pavilion G60-630US  RAM Replacement, Battery: adım 1, 3 resimden 1. HP Pavilion G60-630US  RAM Replacement, Battery: adım 1, 3 resimden 2. HP Pavilion G60-630US  RAM Replacement, Battery: adım 1, 3 resimden 3.
      • Make sure the laptop is powered off and unplugged first.
      • Turn your laptop over so the bottom is facing up.
      • Locate the battery latch and slide the latch switch all the way to the left.
      • The latch will lock and stay in place.
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion G60-630US  RAM Replacement: adım 2, 3 resimden 1. HP Pavilion G60-630US  RAM Replacement: adım 2, 3 resimden 2. HP Pavilion G60-630US  RAM Replacement: adım 2, 3 resimden 3.
      • Carefully lift the battery out and away from the laptop.
      FixBot'a Sor
      Yorum Ekle
    1. HP Pavilion G60-630US  RAM Replacement, RAM: adım 3, 2 resimden 1. HP Pavilion G60-630US  RAM Replacement, RAM: adım 3, 2 resimden 2.
      • Remove the two 5.5 mm JIS#0 screws.
      • Lift the panel up and off the computer.
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion G60-630US  RAM Replacement: adım 4, 3 resimden 1. HP Pavilion G60-630US  RAM Replacement: adım 4, 3 resimden 2. HP Pavilion G60-630US  RAM Replacement: adım 4, 3 resimden 3.
      • Once the panel is removed the RAM card will be visible.
      • The RAM is inserted into its socket with some metal triggers. To remove the RAM card, push the triggers away from the RAM card.
      • If done right, the card will be at an upward angle pointing out of the device.
      • Gently grasp the RAM card ,and pull it out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To insert a new RAM card, put the card into the slot and press down till the metal triggers click over it, holding it in place. After that, follow steps 1 to 3 in reverse order.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 786
