Ana içeriğe geç
HP Pavilion G60-630US Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion G60-630US Hard Drive Replacement, Battery: adım 1, 3 resimden 1. HP Pavilion G60-630US Hard Drive Replacement, Battery: adım 1, 3 resimden 2. HP Pavilion G60-630US Hard Drive Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure the laptop is powered off and unplugged first.
    • Turn your laptop over so the bottom is facing up.
    • Locate the battery latch and slide the latch switch all the way to the left.
    • The latch will lock and stay in place.
  2. HP Pavilion G60-630US Hard Drive Replacement: adım 2, 3 resimden 1. HP Pavilion G60-630US Hard Drive Replacement: adım 2, 3 resimden 2. HP Pavilion G60-630US Hard Drive Replacement: adım 2, 3 resimden 3.
    • Carefully lift the battery out and away from the laptop.
  3. HP Pavilion G60-630US Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Remove the two 5.5 mm JIS#0 screws from the hard drive cover.
    • Remove cover from the back of the laptop.
  4. HP Pavilion G60-630US Hard Drive Replacement: adım 4, 1 resimden 1.
    • Remove three 5.5 mm JIS#0 screws.
  5. HP Pavilion G60-630US Hard Drive Replacement: adım 5, 1 resimden 1.
    • Gently, slide the whole hard drive to the right with your fingers.
  6. HP Pavilion G60-630US Hard Drive Replacement: adım 6, 3 resimden 1. HP Pavilion G60-630US Hard Drive Replacement: adım 6, 3 resimden 2. HP Pavilion G60-630US Hard Drive Replacement: adım 6, 3 resimden 3.
    • Lift up on black tap attached to the hard drive to remove the hard drive.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 740
