Giriş
The power button may not be turning on the laptop. There may be a disconnect of wires or the power bar chip may be defective. If the power button is not working or broken and it needs to be replaced, the following steps show how to replace the components that make the power button work.
Neye ihtiyacın var
Turn your laptop over so the bottom is facing up.
Locate the battery latch and slide the latch switch all the way to the left.
Carefully lift the battery out and away from the laptop.
Missing instructions about removing keyboard screws in the battery bay as well as removing the corner screws on either side of the battery bay.
Open the laptop normally.
Using your fingers (or a spudger if needed), loosen the silver cover surrounding the keyboard.
Carefully place your hands underneath the now loosened keyboard and locate the ribbon keeping the keyboard connected to the laptop.
Locate the tabs keeping the ribbon in place.
Gently push the tabs inward to release the ribbon and to detach the keyboard.
Carefully remove the keyboard and place it off to the side.
Locate the ribbon keeping the power button attached to the laptop.
Push the tab attaching the ribbon to the laptop to detach the silver border and the power button.
My keyboard is held in place by three screws from the back through the battery compartment. The keyboard is then released by prying on the left and right sides near the top. The silver trim is held in place by four screws from the back and the whole piece must be slid toward the display to release plastic fingers underneath before lifting.
Bir Yorum
You have neglected to speak about removal of 5 screws from the bottom of the laptop! 3 inside the battery compartment and 2 on the corners of the laptop. Removal of these allow removal of the bezel and keyboard. Failure to remove these screws will cause damage to the keyboard and bezel!
