Giriş
For the RAM replacement of your laptop, you will need a screwdriver and a couple other tools. This is a relatively easy replacement and should take no more than five minutes.
Neye ihtiyacın var
Slide the battery release switch to the center of the computer to release the battery.
Loosen the 7.25mm screw on the bottom of the laptop holding the "L" shaped cover down.
Bir başkası bu kılavuzu tamamladı.
