Ana içeriğe geç
HP Pavilion G7-2235DX Screen Replacement
Neye ihtiyacın var
  1. HP Pavilion G7-2235DX Screen Replacement, Fan: adım 1, 1 resimden 1.
    • Flip the laptop over and remove six 7.25mm screws.
  2. HP Pavilion G7-2235DX Screen Replacement: adım 2, 2 resimden 1. HP Pavilion G7-2235DX Screen Replacement: adım 2, 2 resimden 2.
    • Using the plastic opening tool or spudger, separate the keyboard from the frame of the laptop.
    • Gently pull the keyboard away from the laptop, toward you, until it is completely separated from the laptop.
  3. HP Pavilion G7-2235DX Screen Replacement: adım 3, 2 resimden 1. HP Pavilion G7-2235DX Screen Replacement: adım 3, 2 resimden 2.
    • Remove the four 7.25mm screws located by the red markers.
  4. HP Pavilion G7-2235DX Screen Replacement: adım 4, 2 resimden 1. HP Pavilion G7-2235DX Screen Replacement: adım 4, 2 resimden 2.
    • Gently lift the panel up, exposing the inside of the laptop.
  5. HP Pavilion G7-2235DX Screen Replacement: adım 5, 2 resimden 1. HP Pavilion G7-2235DX Screen Replacement: adım 5, 2 resimden 2.
    • The fan is located in the top, left hand corner. Now, it can be gently lifted out using your hands.
  6. HP Pavilion G7-2235DX Screen Replacement, Screen: adım 6, 1 resimden 1.
    • To remove the laptop's screen, you will have to remove a total of four 7.25mm screws.
    • First, remove the two 7.25mm screws found in the upper right corner as shown.
  7. HP Pavilion G7-2235DX Screen Replacement: adım 7, 2 resimden 1. HP Pavilion G7-2235DX Screen Replacement: adım 7, 2 resimden 2.
    • Next, unscrew the two 7.25mm screws in the upper left corner of the laptop as shown.
  8. HP Pavilion G7-2235DX Screen Replacement: adım 8, 2 resimden 1. HP Pavilion G7-2235DX Screen Replacement: adım 8, 2 resimden 2.
    • Once all of the screws have been removed, gently lift the laptop's screen from the base of the computer.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Bre'Anna Sanders
113 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-7, Leahy Fall 2016 USF Tampa, Team 1-7, Leahy Fall 2016 üyesi
USFT-LEAHY-F16S1G7
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 448
