Ana içeriğe geç
HP Pavilion G7-2289wm Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion G7-2289wm Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Hard Drive Replacement, Hard Drive: adım 2, 1 resimden 1.
    • Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
    • Pull the edge of the service cover toward you to remove it.
  3. HP Pavilion G7-2289wm Hard Drive Replacement: adım 3, 1 resimden 1.
    • Disconnect the hard drive connector cable from the motherboard.
  4. HP Pavilion G7-2289wm Hard Drive Replacement: adım 4, 1 resimden 1.
    • Lift the front edge of the hard drive, then pull the hard drive out gently.
Sonuç
Ryson Smith
636 İtibar
6 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 185
