Ana içeriğe geç
HP Pavilion G7-2289wm Touchpad Replacement
Neye ihtiyacın var
  1. HP Pavilion G7-2289wm Touchpad Replacement, Battery: adım 1, 1 resimden 1.
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Touchpad Replacement, Hard Drive: adım 2, 1 resimden 1.
    • Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
    • Pull the edge of the service cover toward you to remove it.
  3. HP Pavilion G7-2289wm Touchpad Replacement: adım 3, 1 resimden 1.
    • Disconnect the hard drive connector cable from the motherboard.
  4. HP Pavilion G7-2289wm Touchpad Replacement: adım 4, 1 resimden 1.
    • Lift the front edge of the hard drive, then pull the hard drive out gently.
  5. HP Pavilion G7-2289wm Touchpad Replacement, Keyboard: adım 5, 1 resimden 1.
    • Remove all the screw that secures the keyboard to the computer using a Phillips #0 screwdriver.
  6. HP Pavilion G7-2289wm Touchpad Replacement: adım 6, 3 resimden 1. HP Pavilion G7-2289wm Touchpad Replacement: adım 6, 3 resimden 2. HP Pavilion G7-2289wm Touchpad Replacement: adım 6, 3 resimden 3.
    • Flip your laptop around to the front, using an opening tool, pry around the perimeter of the keyboard.
    • Lift the keyboard from the top backward towards the touch pad.
    • Unlatch the keyboard connector from the motherboard and remove the keyboard.
  7. HP Pavilion G7-2289wm Touchpad Replacement, Touchpad: adım 7, 2 resimden 1. HP Pavilion G7-2289wm Touchpad Replacement, Touchpad: adım 7, 2 resimden 2.
    • Remove the wires attached to the button pad.
  8. HP Pavilion G7-2289wm Touchpad Replacement: adım 8, 1 resimden 1.
    • Carefully lift and remove the button board.
    • Remove all screws from the bottom of the laptop.
Sonuç
Ryson Smith
636 İtibar
6 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 622
