Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
It is possible that your battery has stopped working due to physical or electrical damage. A replacement battery will need to be purchased. After purchasing a new battery follow these steps to replace your broken battery.
  1. Flip the laptop over and locate the grey finger latch.
    • Flip the laptop over and locate the grey finger latch.
  2. Slide the finger latch to the left to release the clip holding the battery into the laptop.
    • Slide the finger latch to the left to release the clip holding the battery into the laptop.
  3. While continuing to hold the finger latch, slowly lift up on the tab to remove the battery from the device. While continuing to hold the finger latch, slowly lift up on the tab to remove the battery from the device.
    • While continuing to hold the finger latch, slowly lift up on the tab to remove the battery from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brandon Boisclair
530 İtibar
3 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team S3-G8, Peak Spring 2018 UMass Dartmouth, Team S3-G8, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G8
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 69
