Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
If the laptop is overheating, it is possible that your fan is malfunctioning or needs to be cleaned. To replace, a replacement must be purchased and installed, while cleaning does not require a new fan. Follow this guide to clean or replace your computer fan.
  1. Locate the fan on the underside of the laptop.
    • Locate the fan on the underside of the laptop.
  2. Using a Phillips #1 screwdriver, remove the 4.5 mm screw securing the fan cover to the device.
    • Using a Phillips #1 screwdriver, remove the 4.5 mm screw securing the fan cover to the device.
  3. Use a plastic spudger tool to free the cover.
    • Use a plastic spudger tool to free the cover.
    • The fan cover is extremely fragile and easy to break. Use caution during this step.
  4. Lift the fan up from the device. If you're cleaning the fan, stop at this step, and remove any build up. This can be done with tweezers and canned air. Disconnect the fan cable to fully remove the fan from the device.
    • Lift the fan up from the device.
    • If you're cleaning the fan, stop at this step, and remove any build up. This can be done with tweezers and canned air.
    • Disconnect the fan cable to fully remove the fan from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Emily Hatstat
481 İtibar
4 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team S3-G8, Peak Spring 2018 UMass Dartmouth, Team S3-G8, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G8
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 61
