Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
If the hard drive in your system failed or you want a larger hard drive (or are upgrading to an SSD), this guide will show you how to access the hard drive for replacement.
==Guide notes==
  • Replacement of the hard drive requires partial disassembly. If you are unsure if you can do the job, have someone who knows how to do it work on it for you.
  • Test the computer before reassembly by only assembling it enough to test for power. If something doesn't work, you will need to tear the whole computer down a second time if you did a complete reassembly.
Parçalar
Hiçbir parça belirtilmedi.
  1. Flip the laptop over and locate the grey finger latch.
    • Flip the laptop over and locate the grey finger latch.
  2. Slide the finger latch to the left to release the clip holding the battery into the laptop.
    • Slide the finger latch to the left to release the clip holding the battery into the laptop.
  3. While continuing to hold the finger latch, slowly lift up on the tab to remove the battery from the device. While continuing to hold the finger latch, slowly lift up on the tab to remove the battery from the device.
    • While continuing to hold the finger latch, slowly lift up on the tab to remove the battery from the device.
  4. To unlock the hard drive,  use a spudger to slide the button aside.
    • To unlock the hard drive, use a spudger to slide the button aside.
  5. Once the button is unlocked to the side, slide the hard drive enclosure away from the device.
    • Once the button is unlocked to the side, slide the hard drive enclosure away from the device.
  6. The hard drive will be clipped into the underside of the hard drive enclosure and can be removed for replacement.
    • The hard drive will be clipped into the underside of the hard drive enclosure and can be removed for replacement.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brandon Boisclair
530 İtibar
3 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team S3-G8, Peak Spring 2018 UMass Dartmouth, Team S3-G8, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G8
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 86
