Ana içeriğe geç
HP Pavilion N3350 Optical Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion N3350 Optical Drive Replacement, Keyboard: adım 1, 2 resimden 1. HP Pavilion N3350 Optical Drive Replacement, Keyboard: adım 1, 2 resimden 2.
    • Open your laptop. Beneath the screen, here is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights.
    • To remove this, pry it open with a spudger tool gently. It should pop out of place.
    FixBot'a Sor
    Yorum Ekle
  2. HP Pavilion N3350 Optical Drive Replacement: adım 2, 2 resimden 1. HP Pavilion N3350 Optical Drive Replacement: adım 2, 2 resimden 2.
    • Remove the three 6mm screws using a Phillips #1 screwdriver.
    • Once the screws are removed, the keyboard is free from the base of the laptop.
    FixBot'a Sor
    Yorum Ekle
  3. HP Pavilion N3350 Optical Drive Replacement: adım 3, 2 resimden 1. HP Pavilion N3350 Optical Drive Replacement: adım 3, 2 resimden 2.
    • Disconnect the green ribbon cable using a plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  4. HP Pavilion N3350 Optical Drive Replacement, Optical Drives: adım 4, 2 resimden 1. HP Pavilion N3350 Optical Drive Replacement, Optical Drives: adım 4, 2 resimden 2.
    • Remove the 6 millimeter screws indicated with a Phillips #1 screwdriver.
    • Remove the top plastic covering from the base of the device.
    FixBot'a Sor
    Yorum Ekle
  5. HP Pavilion N3350 Optical Drive Replacement: adım 5, 2 resimden 1. HP Pavilion N3350 Optical Drive Replacement: adım 5, 2 resimden 2.
    • Use a plastic opening tool to disconnect both cable connectors gently.
    FixBot'a Sor
    Yorum Ekle
  6. HP Pavilion N3350 Optical Drive Replacement: adım 6, 2 resimden 1. HP Pavilion N3350 Optical Drive Replacement: adım 6, 2 resimden 2.
    • Once these cables are disconnected, the optical drives can be found inside.
    • This particular laptop has a CD/DVD combo drive on the left, and a floppy disc drive on the right.
    FixBot'a Sor
    Yorum Ekle
  7. HP Pavilion N3350 Optical Drive Replacement: adım 7, 2 resimden 1. HP Pavilion N3350 Optical Drive Replacement: adım 7, 2 resimden 2.
    • The 1 centimeter screws indicated need to be removed using a Phillips #1 screwdriver to free the CD/DVD combo drive.
    • Once freed, the CD/DVD combo drive should slide out and remove easily.
    FixBot'a Sor
    Yorum Ekle
  8. HP Pavilion N3350 Optical Drive Replacement: adım 8, 2 resimden 1. HP Pavilion N3350 Optical Drive Replacement: adım 8, 2 resimden 2.
    • The 1 centimeter screws indicated must be removed with a Phillips #1 screwdriver to free the floppy disc drive.
    • Remove the floppy disc drive from the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lyndon Davis
124 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G8, Peak Spring 2018 UMass Dartmouth, Team S3-G8, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G8
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 25
Her zaman: 569
