Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Open your laptop. Beneath the screen, here is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights.
To remove this, pry it open with a spudger tool gently. It should pop out of place.
Remove the three 6mm screws using a Phillips #1 screwdriver.
Once the screws are removed, the keyboard is free from the base of the laptop.
Disconnect the green ribbon cable using a plastic opening tool.
Remove the 6 millimeter screws indicated with a Phillips #1 screwdriver.
Remove the top plastic covering from the base of the device.
Use a plastic opening tool to disconnect both cable connectors gently.
Once these cables are disconnected, the optical drives can be found inside.
The 1 centimeter screws indicated need to be removed using a Phillips #1 screwdriver to free the CD/DVD combo drive.
Once freed, the CD/DVD combo drive should slide out and remove easily.
The 1 centimeter screws indicated must be removed with a Phillips #1 screwdriver to free the floppy disc drive.
Remove the floppy disc drive from the device.
Bir başkası bu kılavuzu tamamladı.
