Ana içeriğe geç
HP Pavilion N3350 RAM Replacement
Neye ihtiyacın var
  1. HP Pavilion N3350 RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Locate the RAM on the bottom side of the laptop, the cover is secured by a 6 millimeter screw. Remove this with a Philips #1 screwdriver.
  2. HP Pavilion N3350 RAM Replacement: adım 2, 1 resimden 1.
    • Underneath are the RAM boards. They are secured by two plastic clips each. Locate these to continue removal.
  3. HP Pavilion N3350 RAM Replacement: adım 3, 1 resimden 1.
    • Place your thumbs on two of the clips securing one board. Push outwards on the clips. This should pop the board up.
  4. HP Pavilion N3350 RAM Replacement: adım 4, 1 resimden 1.
    • Repeat on second board. When both are released, they should appear as they do in the picture.
  5. HP Pavilion N3350 RAM Replacement: adım 5, 1 resimden 1.
    • The RAM should be easily removed once released from the plastic clips.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Brandon Boisclair
530 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G8, Peak Spring 2018 UMass Dartmouth, Team S3-G8, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G8
3 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Windows 98 Product Key?
Dudefoxlive - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 130
