Ana içeriğe geç
HP Pavilion N3350 Screen Assembly Replacement
Neye ihtiyacın var
  1. HP Pavilion N3350 Screen Assembly Replacement, Screen Assembly: adım 1, 2 resimden 1. HP Pavilion N3350 Screen Assembly Replacement, Screen Assembly: adım 1, 2 resimden 2.
    • Open your laptop. Beneath the screen, there is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights.
    • To remove this, pry it open with a spudger tool gently. It should pop out of place.
  2. HP Pavilion N3350 Screen Assembly Replacement: adım 2, 2 resimden 1. HP Pavilion N3350 Screen Assembly Replacement: adım 2, 2 resimden 2.
    • Gently use a spudger tool or your fingers to disconnect the LCD cable from the screen.
    • This is one of three connectors that needs to be undone to disconnect the screen from the laptop.
  3. HP Pavilion N3350 Screen Assembly Replacement: adım 3, 3 resimden 1. HP Pavilion N3350 Screen Assembly Replacement: adım 3, 3 resimden 2. HP Pavilion N3350 Screen Assembly Replacement: adım 3, 3 resimden 3.
    • Remove the 1 cm screw with a Phillips #1 screwdriver to allow the screen and top of the laptop to be separated from the keyboard and bottom.
    • Lift the entire top away from the bottom, and set bottom half of the laptop aside.
  4. HP Pavilion N3350 Screen Assembly Replacement: adım 4, 3 resimden 1. HP Pavilion N3350 Screen Assembly Replacement: adım 4, 3 resimden 2. HP Pavilion N3350 Screen Assembly Replacement: adım 4, 3 resimden 3.
    • Remove the 6 rubber screw caps with a metal spudger.
    • After removing the 6 rubber screw caps, use a Phillips #1 screwdriver to unscrew the six 6mm screws.
  5. HP Pavilion N3350 Screen Assembly Replacement: adım 5, 2 resimden 1. HP Pavilion N3350 Screen Assembly Replacement: adım 5, 2 resimden 2.
    • To separate the plastic cover, use a plastic opening tool to undo each plastic connecting clip between the two.
    • You can find the plastic connecting clips by sliding the plastic opening tool along the seam between the two plastic covers.
    • Remove the top plastic cover once all connections have been released.
  6. HP Pavilion N3350 Screen Assembly Replacement: adım 6, 3 resimden 1. HP Pavilion N3350 Screen Assembly Replacement: adım 6, 3 resimden 2. HP Pavilion N3350 Screen Assembly Replacement: adım 6, 3 resimden 3.
    • Disconnect the connectors using a plastic opening tool.
    • Once these two connectors are released, the screen should be electronically freed from the rest of the laptop.
  7. HP Pavilion N3350 Screen Assembly Replacement: adım 7, 1 resimden 1.
    • At each corner, there is a 1 centimeter silver screw connecting the screen frame to the laptop. Remove these using a Phillips #1 Screwdriver.
  8. HP Pavilion N3350 Screen Assembly Replacement: adım 8, 3 resimden 1. HP Pavilion N3350 Screen Assembly Replacement: adım 8, 3 resimden 2. HP Pavilion N3350 Screen Assembly Replacement: adım 8, 3 resimden 3.
    • There should be thin piece of copper 'tape' holding the LCD cable down. Remove this gently with tweezers.
    • Remove the screen from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Emily Hatstat
481 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G8, Peak Spring 2018 UMass Dartmouth, Team S3-G8, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G8
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 16
Her zaman: 176
