Ana içeriğe geç
HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement
Neye ihtiyacın var
  1. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
  2. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: adım 2, 2 resimden 1. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: adım 2, 2 resimden 2.
    • Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
  3. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: adım 3, 2 resimden 1. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: adım 3, 2 resimden 2.
    • Carefully pull the battery away from the device.
  4. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement, Cooling Fan: adım 4, 1 resimden 1.
    • Using a Phillips #0 screwdriver, unscrew all nine of the screws from the bottom of the computer.
    • There is a wire connecting the keyboard to the motherboard. Do not pull the keyboard away until you have disconnected the wire.
  5. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: adım 5, 3 resimden 1. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: adım 5, 3 resimden 2. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: adım 5, 3 resimden 3.
    • Using a plastic opening tool, pry up along the edge of the keyboard.
    • There is a wire connecting the keyboard to the motherboard. Do not completely pull the keyboard off until the wire is disconnected.
  6. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: adım 6, 3 resimden 1. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: adım 6, 3 resimden 2. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: adım 6, 3 resimden 3.
    • To disconnect the wire, pry up on the latch connecting it to the motherboard.
  7. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: adım 7, 3 resimden 1. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: adım 7, 3 resimden 2. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: adım 7, 3 resimden 3.
    • Using a plastic or metal spudger, carefully pry apart the palm rest from the rest of the laptop.
    • Be careful when using the metal spudger, as you could damage the internal components if the spudger is inserted too far.
    • Do not completely pull the halves apart yet because there are still wires holding them together.
  8. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: adım 8, 3 resimden 1. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: adım 8, 3 resimden 2. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: adım 8, 3 resimden 3.
    • Disconnect the touch pad wire by flipping the black lever with a plastic spudger.
  9. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: adım 9, 2 resimden 1. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: adım 9, 2 resimden 2.
    • Unscrew the circuit board underneath the power button.
    • Remove this circuit board by pulling up and away on the plastic tab.
  10. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: adım 10, 3 resimden 1. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: adım 10, 3 resimden 2. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: adım 10, 3 resimden 3.
    • Using a Phillips #0 screwdriver, remove all the screws and take the metal plate off the mother board.
    • Double sided tape holds the plate down as well as the screws. You will need to apply force to remove the plate.
  11. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: adım 11, 2 resimden 1. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: adım 11, 2 resimden 2.
    • Remove the three screws holding the cooling fan in place using a Phillips #0 screwdriver.
    • Using a plastic opening tool, remove the power cable for the fan.
    • Remove the fan from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Josh Svik
281 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 363
