Ana içeriğe geç
Giriş
This guide will walk you through the steps required to remove and replace the keyboard of the HP Pavilion Sleekbook 14-b013cl.
Parçalar
Hiçbir parça belirtilmedi.
  1. Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon). Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
    • Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
  2. Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery. Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
    • Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
  3. Carefully pull the battery away from the device. Carefully pull the battery away from the device.
    • Carefully pull the battery away from the device.
  4. Using the Phillips #0 screwdriver, remove the two screws.
    • Using the Phillips #0 screwdriver, remove the two screws.
  5. Use a plastic opening tool to pry up one of the upper counters on the keyboard Run the tool along the upper edge of the keyboard and towards the opposite corner to release the latches. Run the tool along the upper edge of the keyboard and towards the opposite corner to release the latches.
    • Use a plastic opening tool to pry up one of the upper counters on the keyboard
    • Run the tool along the upper edge of the keyboard and towards the opposite corner to release the latches.
  6. Push the button to release the connector and pull it out and remove the keyboard Push the button to release the connector and pull it out and remove the keyboard Push the button to release the connector and pull it out and remove the keyboard
    • Push the button to release the connector and pull it out and remove the keyboard
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 8
Her zaman: 132
