Ana içeriğe geç
HP Pavilion Sleekbook 15-b000 Keyboard Replacement
Neye ihtiyacın var
  1. HP Pavilion Sleekbook 15-b000 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Unplug laptop from adapter and all other devices.
  2. HP Pavilion Sleekbook 15-b000 Keyboard Replacement: adım 2, 1 resimden 1.
    • Flip the laptop over with battery facing you.
  3. HP Pavilion Sleekbook 15-b000 Keyboard Replacement: adım 3, 2 resimden 1. HP Pavilion Sleekbook 15-b000 Keyboard Replacement: adım 3, 2 resimden 2.
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. HP Pavilion Sleekbook 15-b000 Keyboard Replacement: adım 4, 1 resimden 1.
    • Pull battery out.
  5. HP Pavilion Sleekbook 15-b000 Keyboard Replacement, Keyboard: adım 5, 1 resimden 1.
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. HP Pavilion Sleekbook 15-b000 Keyboard Replacement: adım 6, 1 resimden 1.
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. HP Pavilion Sleekbook 15-b000 Keyboard Replacement: adım 7, 1 resimden 1.
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  8. HP Pavilion Sleekbook 15-b000 Keyboard Replacement: adım 8, 1 resimden 1.
    • Remove keyboard wire by popping latch under blue plastic
Sonuç
Sam Barkley
983 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S11-G2, Cheng Spring 2018 USF Tampa, Team S11-G2, Cheng Spring 2018 üyesi
USFT-CHENG-S18S11G2
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 265
