Giriş
This guide will show you the procedure how to remove and reset your RAM on the motherboard if it has become damaged and no longer works and needs to be replaced or may have become disconnected or loose.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Using the spudger to lift up on the white tabs
Pull horizontally on the blue ribbon to disconnect the cables
2 farklı kişi bu kılavuzu tamamladı.
