Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Slide the battery lock on the right side open.
Slide the Battery release latch on the left side.
Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
Push screwdriver through screw hole top pop the keyboard.
Remove keyboard wire by popping latch under blue plastic
Using the spudger to lift up on the white tabs
Pull horizontally on the blue ribbon to disconnect the cables
Remove the five 5.5mm Phillips #1 screws from the case
Remove eight 6.5mm Phillips #1 screws from the back cover
Starting at a top corner, use the pry tool to split the case.
Slowly work around the case, pulling up gently to release the clips.
Disconnect motherboard cable from left side USB and jacks
Remove the six 5.5mm Phillips #1 motherboard screws
Remove the one 3.5mm Phillips #1 screw from the WiFi chip
Pull the clips attaching the ram outwards.
Remove ram at a angle.
2 farklı kişi bu kılavuzu tamamladı.
