Ana içeriğe geç
HP Pavilion Sleekbook 15-b000 Speaker Replacement
Neye ihtiyacın var
  1. HP Pavilion Sleekbook 15-b000 Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Unplug laptop from adapter and all other devices.
  2. HP Pavilion Sleekbook 15-b000 Speaker Replacement: adım 2, 1 resimden 1.
    • Flip the laptop over with battery facing you.
  3. HP Pavilion Sleekbook 15-b000 Speaker Replacement: adım 3, 2 resimden 1. HP Pavilion Sleekbook 15-b000 Speaker Replacement: adım 3, 2 resimden 2.
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. HP Pavilion Sleekbook 15-b000 Speaker Replacement: adım 4, 1 resimden 1.
    • Pull battery out.
  5. HP Pavilion Sleekbook 15-b000 Speaker Replacement, Keyboard: adım 5, 1 resimden 1.
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. HP Pavilion Sleekbook 15-b000 Speaker Replacement: adım 6, 1 resimden 1.
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. HP Pavilion Sleekbook 15-b000 Speaker Replacement: adım 7, 1 resimden 1.
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  8. HP Pavilion Sleekbook 15-b000 Speaker Replacement: adım 8, 1 resimden 1.
    • Remove keyboard wire by popping latch under blue plastic
  9. HP Pavilion Sleekbook 15-b000 Speaker Replacement, Case: adım 9, 1 resimden 1.
    • Using the spudger to lift up on the white tabs
    • Pull horizontally on the blue ribbon to disconnect the cables
  10. HP Pavilion Sleekbook 15-b000 Speaker Replacement: adım 10, 1 resimden 1.
    • Remove the five 5.5mm Phillips #1 screws from the case
  11. HP Pavilion Sleekbook 15-b000 Speaker Replacement: adım 11, 1 resimden 1.
    • Remove eight 6.5mm Phillips #1 screws from the back cover
  12. HP Pavilion Sleekbook 15-b000 Speaker Replacement: adım 12, 3 resimden 1. HP Pavilion Sleekbook 15-b000 Speaker Replacement: adım 12, 3 resimden 2. HP Pavilion Sleekbook 15-b000 Speaker Replacement: adım 12, 3 resimden 3.
    • Starting at a top corner, use the pry tool to split the case.
    • Slowly work around the case, pulling up gently to release the clips.
  13. HP Pavilion Sleekbook 15-b000 Speaker Replacement, Motherboard: adım 13, 2 resimden 1. HP Pavilion Sleekbook 15-b000 Speaker Replacement, Motherboard: adım 13, 2 resimden 2.
    • Disconnect motherboard cable from left side USB and jacks
  14. HP Pavilion Sleekbook 15-b000 Speaker Replacement: adım 14, 1 resimden 1.
    • Remove the six 5.5mm Phillips #1 motherboard screws
    • Remove the one 3.5mm Phillips #1 screw from the WiFi chip
  15. HP Pavilion Sleekbook 15-b000 Speaker Replacement: adım 15, 1 resimden 1.
    • Remove motherboard.
  16. HP Pavilion Sleekbook 15-b000 Speaker Replacement, Speaker: adım 16, 3 resimden 1. HP Pavilion Sleekbook 15-b000 Speaker Replacement, Speaker: adım 16, 3 resimden 2. HP Pavilion Sleekbook 15-b000 Speaker Replacement, Speaker: adım 16, 3 resimden 3.
    • Use a plastic opening tool to carefully remove the right speaker.
    • Repeat this step for the left speaker.
Sonuç
Sam Barkley
1.007 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S11-G2, Cheng Spring 2018 USF Tampa, Team S11-G2, Cheng Spring 2018 üyesi
USFT-CHENG-S18S11G2
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 232
