Ana içeriğe geç
HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Remove the battery from the device and unplug it.
    • Keep different sized screws separated from each other during disassembly and reassembly.
  2. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the two screws on the small back cover.
    • Remove the cover.
    • Remove the three screws that have been uncovered.
  3. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Remove the two rubber screw covers by the rubber feet of the device.
    • Using a Phillips #0 screwdriver, remove the two screws that have been uncovered.
  4. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the eight screws as directed.
    • Using a Phillips #1 screwdriver, remove the two remaining screws.
  5. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: adım 5, 2 resimden 1. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Using the plastic opening tool, gently pull up the keyboard starting from the bottom left corner, working your way to the bottom right corner.
    • To remove the keyboard, lift up the plastic retaining tab with the opening tool and gently pull out the ribbon wire.
  6. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: adım 6, 1 resimden 1.
    • Remove the plastic cover of the laptop using the opening tool.
    • The plastic cover is fragile, be cautious during removal.
  7. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Using the plastic opening tool, pull up the retaining tab and and pull out the ribbon wire
    • This port is fragile, take care in removing and reinserting the ribbon wire.
  8. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: adım 8, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the six screws on the hard drive, then remove it.
    • Be sure to properly dispose or recycle your hard drive.
Sonuç
Justin Hurley
1 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S6-G6, Wilson Spring 2019 IUPUI, Team S6-G6, Wilson Spring 2019 üyesi
IUPUI-WILSON-S19S6G6
3 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 346
