Ana içeriğe geç
HP Pavilion TouchSmart 14z-n100 Ram Replacement
Neye ihtiyacın var
  1. HP Pavilion TouchSmart 14z-n100 Ram Replacement, Ram: adım 1, 2 resimden 1. HP Pavilion TouchSmart 14z-n100 Ram Replacement, Ram: adım 1, 2 resimden 2.
    • Remove the two #1 Phillips 4mm screws that hold the cover in place.
  2. HP Pavilion TouchSmart 14z-n100 Ram Replacement: adım 2, 3 resimden 1. HP Pavilion TouchSmart 14z-n100 Ram Replacement: adım 2, 3 resimden 2. HP Pavilion TouchSmart 14z-n100 Ram Replacement: adım 2, 3 resimden 3.
    • Use the plastic opening tool to remove the cover. There are several clips that hold it on.
    • Carefully slide the plastic opening tool under the edge of the cover until it comes loose.
    • You can now remove the cover.
  3. HP Pavilion TouchSmart 14z-n100 Ram Replacement: adım 3, 3 resimden 1. HP Pavilion TouchSmart 14z-n100 Ram Replacement: adım 3, 3 resimden 2. HP Pavilion TouchSmart 14z-n100 Ram Replacement: adım 3, 3 resimden 3.
    • There are 4 clips total, one on each side of the RAM.
    • Remove the ram by pushing the clamps outward, away from the ram
    • After the pushing the clamps outward the ram should lift up and be able to slide out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Daniel Zwissler
97 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G4, Arle Fall 2018 IUPUI, Team S1-G4, Arle Fall 2018 üyesi
IUPUI-ARLE-F18S1G4
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 85
