Ana içeriğe geç
HP Pavilion Touchsmart 11z-e000 Keyboard Replacement
Neye ihtiyacın var
  1. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
  2. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement, Keyboard: adım 2, 1 resimden 1.
    • Use a spudger to slide under the outer plastic cover of the laptop and lift it up and away.
    • Pull off the plastic cover of the laptop.
  3. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: adım 3, 1 resimden 1.
    • Remove all of the silver screws connecting the keyboard plate to the rest of the laptop.
    • This step allows the top plate to be removed from the body of the laptop in the following step.
    12- M2x4 screws to remove. And it helps to remove the screws holding the elbow because it releases the front plate at the top corners.
    Con Fran - Yanıt
  4. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: adım 4, 1 resimden 1.
    • Use a spudger to lift the keyboard plate off of the base of the computer.
    • Some areas near the hinges may be connected with an adhesive. Take care when removing the plate in these regions.
  5. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: adım 5, 1 resimden 1.
    • Remove the screws connecting the keyboard to the underside of the plate
    • Detach the ribbon wire connecting the keyboard to the hardware.
    • This picture shows the underside of the keyboard after it is removed from the laptop.
  6. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: adım 6, 1 resimden 1.
    • Slowly separate the main part of the keyboard from the metal plate by pressing firmly on the key side of the keyboard and lifting from the back side.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Robert Hemphill
269 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-22, Maness Winter 2015 Cal Poly, Team 21-22, Maness Winter 2015 üyesi
CPSU-MANESS-W15S21G22
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Where can I find a replacement keyboard for the hp pavilion ts 11-e110nr? I've tried a basic search and also Amazon and eBay, but I can't find one anywhere.
Con Fran - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 6
Her zaman: 1,655
