Ana içeriğe geç
HP Pavilion Wave 600-a014 Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion Wave 600-a014 Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Disconnect the PC from power source and any other devices.
  2. HP Pavilion Wave 600-a014 Hard Drive Replacement: adım 2, 2 resimden 1. HP Pavilion Wave 600-a014 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Turn the computer over and remove the rubber feet.
    • Remove the three 8mm Philips screws with a Philips #0 Screwdriver.
    • Use a pry tool and lift up on the lid.
  3. HP Pavilion Wave 600-a014 Hard Drive Replacement: adım 3, 2 resimden 1. HP Pavilion Wave 600-a014 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Remove the two cables circled in red for the front IO panel.
  4. HP Pavilion Wave 600-a014 Hard Drive Replacement: adım 4, 2 resimden 1. HP Pavilion Wave 600-a014 Hard Drive Replacement: adım 4, 2 resimden 2.
    • From back IO panel pry open the casing as indicated.
  5. HP Pavilion Wave 600-a014 Hard Drive Replacement: adım 5, 3 resimden 1. HP Pavilion Wave 600-a014 Hard Drive Replacement: adım 5, 3 resimden 2. HP Pavilion Wave 600-a014 Hard Drive Replacement: adım 5, 3 resimden 3.
    • To remove the hard drive, remove the four 8mm Philips screws using a Philips #0 Screwdriver.
    • Remove Power and SATA cables from on top of the drive.
  6. HP Pavilion Wave 600-a014 Hard Drive Replacement: adım 6, 1 resimden 1.
    • After screws have been removed grab the Hard Drive and pull it out of the dock.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Cristian Vanegas
297 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S8-G4, Banghart Fall 2017 Cal Poly, Team S8-G4, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S8G4
4 Üyeler
5 adet Kılavuz yazıldı
2 Yorum
Hi there, can you advise whether this was the 128gb SSD or the other 2gb drive?
Joey Franco - Yanıt
This model comes with a 3.5" 1TB HDD standard.
Jay Marble -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 38
Her zaman: 2,369
