Ana içeriğe geç
HP Pavilion Wave 600-a014 RAM Replacement
Neye ihtiyacın var
  1. HP Pavilion Wave 600-a014 RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Disconnect PC from power source and any other devices.
  2. HP Pavilion Wave 600-a014 RAM Replacement: adım 2, 2 resimden 1. HP Pavilion Wave 600-a014 RAM Replacement: adım 2, 2 resimden 2.
    • Turn over computer and remove the rubber feet.
    • Remove the three 8mm Philips screws with a Philips #0 screwdriver.
    • Use a pry tool and lift up on the lid.
  3. HP Pavilion Wave 600-a014 RAM Replacement: adım 3, 2 resimden 1. HP Pavilion Wave 600-a014 RAM Replacement: adım 3, 2 resimden 2.
    • Remove the two cables connecting the motherboard to the front I/O panel.
  4. HP Pavilion Wave 600-a014 RAM Replacement: adım 4, 2 resimden 1. HP Pavilion Wave 600-a014 RAM Replacement: adım 4, 2 resimden 2.
    • From the back I/O panel, pry open the cloth covering.
  5. HP Pavilion Wave 600-a014 RAM Replacement: adım 5, 1 resimden 1.
    • Remove the 2 black philips screws on the outside of the PC, to the left of the fan.
    • There is one on the top and one on the bottom.
  6. HP Pavilion Wave 600-a014 RAM Replacement: adım 6, 3 resimden 1. HP Pavilion Wave 600-a014 RAM Replacement: adım 6, 3 resimden 2. HP Pavilion Wave 600-a014 RAM Replacement: adım 6, 3 resimden 3.
    • Put your thumb on the penny-sized hole, and slide the panel upwards.
    • Remove the panel to reveal the stock blue RAM.
  7. HP Pavilion Wave 600-a014 RAM Replacement: adım 7, 3 resimden 1. HP Pavilion Wave 600-a014 RAM Replacement: adım 7, 3 resimden 2. HP Pavilion Wave 600-a014 RAM Replacement: adım 7, 3 resimden 3.
    • Push both of the white tabs away from the RAM stick to free the RAM.
  8. HP Pavilion Wave 600-a014 RAM Replacement: adım 8, 1 resimden 1.
    • You can now easily pull the RAM out of the socket, and replace up to two new ones!
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Arthur Knatt
149 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S8-G4, Banghart Fall 2017 Cal Poly, Team S8-G4, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S8G4
4 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Hello srs, i follow the link to the Amazon Ram, and it is So-DIMM, but we need UDIMM for this Wave, it is correct? Wich can we use? Thank you so much, and best regards.
Albert Garcia - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 2,976
